Disables the EDP on one or more ports.
ports |
Specifies one or more ports or slots and ports, including management port. |
all |
Specifies all ports on the switch, including management port. |
Enabled.
You can use the disable edp ports command to disable EDP on one or more ports when you no longer need to locate neighbor Extreme Networks switches.
The following command disables EDP on ports 2 and 4 on a switch:
disable edp ports 2,4
Ability to disable EDP on management port was added in ExtremeXOS 30.1.
